JMP Knowledge Base
My Nonlinear model is not converging. Why?
Convergence might not be attained under certain conditions. These may include the following:
  • incorrect specification of the model
  • poor initial starting values
  • an over-defined model
  • insufficient data
Nonlinear models are very sensitive to initial estimates. If these values are not good, the model might not converge. Also, your data might not support the number of parameters you are trying to estimate.
[Previously JMP Note 36640]
Details
Operating System
macOS Windows
Products JMP JMP Pro
