JMP Knowledge Base
Mortality Time to Event can incorrectly calculate the number of deaths
Processing the DS domain data set made algorithmic assumptions of where to look for values representing death that would lead to not accurately counting/finding death records depending on the record order and disposition event categorization. Any studies/reports that used this analysis should be regenerated after applying the Hot Fix found here to avoid any possibility of death miscalculation.
[Previously JMP Note 62108]
Details
Operating System
Windows
Reported Version
6.1
Fixed Version
7.0
Products JMP Clinical
