JMP Knowledge Base
Missing values in SAS® datasets might be imported incorrectly
When connecting to local SAS® using a 64-bit version of JMP®, the 64-bit SAS 9.4 IOM OLE DB provider used to import SAS datasets will import missing data with incorrect values. This problem is limited to importing data from local SAS using a 64-bit version of JMP where the 64-bit SAS 9.4 TS1M0 version of the SAS IOM OLE DB provider is installed.
The recommended workaround for this issue is to install the updated version of the SAS IOM OLE DB provider available with SAS 9.4 TS1M1.
[Previously JMP Note 51039]
Details
Operating System
Windows
Products JMP JMP Pro
