JMP Knowledge Base
Metadata table files are overwritten if a mapped drive connection is lost when managing a configuration
In JMP® Clinical 7.1, if a mapped drive connection is lost while managing a configuration, metadata files are overwritten. You might encounter the following JMP Alert:
date rc=0 in access or evaluation of 'Last Modification Date', Bad Argument (narrDestPath||narrfileName||".VM"), Last Modification Date/*###*/(narrDestPath||narrfileName||".VM")
This issue is corrected in the JMP® Clinical 7.1.2 hot fix (link below).
[Previously JMP Note 65965]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
