Match function may not work as expected if matching with numeric continuous values
Nov 30, 2022 04:34 PM
The Match function is typically used with categorical or ordinal values. It is possible to use numeric continuous values, but because of numeric precision, rounding off the values using the Round function may be needed.
[Previously JMP Note 35526]
Details
Operating System
macOS
Windows
Reported Version
14.0
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '575370' && "TkbArticlePage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '575370') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if ("TkbArticlePage" == "IdeaPage") {
if (value == '575370') {
if ("TkbArticlePage" == "TkbArticlePage") {
if(subTkbElement){
else if ("TkbArticlePage" == "BlogArticlePage") {
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
