JMP Knowledge Base
JMP® stops responding when running a Wilcoxon Exact Test with ties
In a Fit Y by X ► One-way analysis, ties in the data cause JMP to stop responding when attempting to run a Wilcoxon Exact Test.
In this situation, the only option is to produce the normal approximation result by selecting Nonparametric ► Wilcoxon Test.
[Previously JMP Note 60641]
Details
Operating System
macOS Windows
Reported Version
14.0
Fixed Version
17.0
Products JMP JMP Pro
