JMP Knowledge Base
JMP® might stop responding when a network drive with JMP files becomes unavailable
The Recent Files window in JMP verifies the availability of the files in its list. If a file in the Recent Files list that resides on a network drive becomes unavailable, JMP can stop responding while waiting to verify it.
If you are experiencing this issue, it is recommended that you upgrade to JMP 15 or a newer version.
If you experience the issue but are unable to upgrade to JMP 15 or a newer version, contact JMP Technical Support for additional assistance.
[Previously JMP Note 66188]
Details
Operating System
macOS Windows
Reported Version
14.0
Fixed Version
15.0
Products JMP JMP Pro
