JMP Knowledge Base
JMP is not able to import data returned by executing a stored procedure which returns an Oracle cursor
Stored procedures can be executed from JMP® after connecting to a database via ODBC and clicking on the Advanced button. However, stored procedures which return an Oracle cursor will not result in the data being imported into JMP®. Data is only returned to JMP® if a SQL SELECT query is used.
[Previously JMP Note 34878]
Details
Operating System
macOS Windows
Products JMP
