JMP Knowledge Base
JMP® for Windows Fails to Launch with No Error Messages
In situations where JMP fails to launch, and no error messages are displayed, the most common problem is missing or corrupt Microsoft® Visual C++ Redistributable components.
JMP Software for Windows, including JMP, JMP Pro, JMP Clinical, and JMP Student Edition, utilize several Microsoft technologies, including the Visual C++ Redistributable components.
The best way to address Microsoft Visual C++ Redistributable issues is to reinstall them.
**IMPORTANT** After reinstall the Microsoft Visual C++ Redistributables, a reboot is required.
Due to changes in how the Visual C++ Redistributables are provided, this note is organized based on the installed JMP version as follows:
JMP 19.0.3 and newer
JMP 19.0.1 and older (including JMP 18)
JMP 19.0.3 and Newer
Beginning in JMP 19.0.3, JMP provides the Microsoft Visual C++ Redistributable components inside the Windows install location.  See reference below for your product.  {version} refers to the version of the JMP software you are using (i.e. 19).
Product
Location
JMP
C:\Program Files\JMP\JMP\{version}\Extra
JMP Pro
C:\Program Files\JMP\JMPPRO\{version}\Extra
JMP Clinical
C:\Program Files\JMP\JMPCLINICAL\{version}\Extra
JMP Student
C:\Program Files\JMP\JMPSTUDENT\{version}\Extra
How to Re-Install the Microsoft® Visual C++ Redistributable Delivered with JMP® Software for Windows
After identifying the location of the Visual C++ Redistributable components, please find two installers: one 32-bit installer (i.e. vcredist_x86_2022.exe) and one 64-bit installer (i.e. vcredist_x64_2022.exe).  Copy both files to your Desktop.
From your Desktop, run each installer individually.  After running both installers, please reboot your computer to ensure the necessary changes are correctly applied.
After rebooting, please launch JMP again.
JMP 19.0.1 and Older
In JMP 19.0.1 and older versions of JMP, the Visual C++ Redistributables were not provided after the installation completed.
To access the Visual C++ files, please download them from the Microsoft Visual C++ Redistributable Download website.
How to Re-Install the Microsoft® Visual C++ Redistributable Downloaded
Download both the x64 and x32 versions of the Microsoft Visual C++ Redistributables.
Save them your Desktop.
Additionally Troubleshooting Steps
In some cases, Windows will not allow installing the same version of the Visual C++ Redistributable components over themself.  In this situation, the existing Visual C++ Redistributable components must first be uninstalled, both the 32-bit (x86) and 64-bit (x64) versions.
You can see how to uninstall applications on Windows using this Microsoft article. https://support.microsoft.com/en-us/windows/uninstall-or-remove-apps-and-programs-in-windows-4b55f97...
You will be looking for applications that look like this:
Microsoft Visual C++ v14 Redistributable (x86) - 14.50.35719
Microsoft Visual C++ v14 Redistributable (x64) - 14.50.35719
After uninstalling, please reboot before attempting to install the Visual C++ Redistributable components.
If this JMP Note does not resolve your issue, please contact JMP Technical Support.
Details
Products JMP JMP Pro JMP Clinical
