JMP Knowledge Base
JMP error: The installed version of the application could not be determined
When installing or updating JMP software, the following error could occur:
To resolve this, right-click the installation file and choose "Run as Administrator."
Administrative credentials are required. If you do not have admin rights, contact your local IT department.
Details
Operating System
Windows
Products JMP JMP Pro JMP Clinical
