JMP Knowledge Base
JMP® date columns are exported as character data types through ODBC
When exporting a JMP® data table to a database using ODBC, JMP exports the data as either character (CHAR or NCHAR) or numeric (FLOAT or DOUBLE PRECISION) data types. If a column is defined as a JMP date or time, it exports as character data. Changing the data type to a proper date format would need to be handled by the receiving database.
[Previously JMP Note 46350]
Details
Operating System
macOS Windows
Products JMP JMP Pro
