JMP Knowledge Base
JMP Live SSL certificate requirements
JMP Live uses HTTPS/TLS and relies on a certificate in two main places:
1) JMP Live web and pool servers
JMP Live web and pool can be the same server.
They are used here to secure traffic between browsers and JMP Live.
Requirements:
  • A valid SSL/TLS certificate issued for the JMP Live hostname
    (e.g. yourserver.dev.jmp.com)
  • The certificate should be in PEM format and can be opened in Notepad to ensure proper formatting.
    The three parts used for JMP Live are:
    • Server certificate used in JMP Live web installation
      -----BEGIN CERTIFICATE-----
      (server cert)
      -----END CERTIFICATE-----
    • Private key used in JMP Live web installation
      -----BEGIN PRIVATE KEY-----
      (private key)
      -----END PRIVATE KEY-----
    • Root CA / CA Chain used in JMP Live web and pool installation
      (intermediate CA)
      (root CA)
Notes of importance:
  • Certificates for JMP Live web and pool must be in PEM format
  • Ensure there are no carriage returns above or below the certificates
  • Remove any Attributes above or below the certificates
  • These certificates must be trusted by client machines
2) SSL Certificate for Keycloak installation:
JMP Live authentication requires Keycloak, which also needs its own certificate.
Requirements:
  • A valid certificate for the Keycloak host
    (often same domain family, e.g. auth.dev.jmp.com)
  • Certificate required for installation. These can also be opened in Notepad to ensure proper formatting:
      (private key)
    • Keycloak Certificate
      (server certificate)
      (intermediate CA)
      (root ca)
  • The certificate for Keycloak should be .cert format
To test the validity of your JMP Live certificate, run the following:
  • Start menu > Node.js command prompt (Run as Admin)
  • cd to C:\Program Files\JMP\JMP Live\JMPLive
  • npm run check-ssl
Please note, JMP Statistical Discovery cannot generate the certificate required for JMP Live.
The certificate is organization-specific and must come from third-party vendors such as DigiCert, Symantec, or Network Solutions, or from an internal enterprise certificate authority (CA).
For a more detailed explanation of SSL Certificates needed for JMP Live, please refer to this blog post.
Details
Products JMP Live
