JMP Knowledge Base
JMP® Help might not direct you to the correct Help page when you are using the Safari browser on a macOSX system
There is a known issue with JMP Help not redirecting you to the correct page when you are using non-English settings for Safari on macOSX. Instead of being directed to the specific Help documentation page that you requested, you are directed to a generic Help page for your version of JMP.
The workaround is to use Google Chrome as the default web browser instead.
[Previously JMP Note 67156]
Details
Operating System
macOS
Reported Version
15.0
Products JMP
