JMP Knowledge Base
JMP® Get Data for x fails using R 4.2.x and later
R 4.2.x versions are currently not working with various JSL R functions that pull data from R.
To address this issue, SAS recommends that you downgrade to an R 4.1.x version to use the R integration with JMP.
Note: Reference JMP Note 575310 when considering using the integration on Apple (macOS) silicon arm (M1) architecture.
[Previously JMP Note 69504]
Details
Operating System
macOS Windows
Reported Version
17.0
Fixed Version
17.1
Products JMP JMP Pro
