JMP Knowledge Base
JMP® Genomics stops responding when you load a setting or run predictive modeling on large data files
JMP® Genomics 10 might stop responding when you load a settings file, if the setting references a large data file. This problem occurs when you load settings either by selecting File ► Load Life Sciences Setting or by clicking the Load button in a process dialog window.
A workaround is to specify the parameters manually in the dialog window instead of loading the settings file.
The Predictive Modeling Review process and the Model Comparison process might also stop responding for large data sets (because they rely on loading settings files). There is currently no workaround for this issue.
[Previously JMP Note 66490]
Details
Operating System
Windows
Reported Version
10.0
Products JMP Genomics
