JMP Knowledge Base
JMP® Clinical presents security warning when opening files on that contains scripts from safe locations.
Problem: JMP® Clinical will present Windows Security warnings stating "The downloaded table contains scripts. Open anyway? Choose Examine to open the table with the scripts disabled". This occurs for local files or files located in network locations that have been added to trusted local internet zones in accordance with JMP Note 575245.
This issue occurs because the Web Browser in reports used to display a description of the report when users select reports to add to a Review.
Workaround: There is an option within JMP Clinical that each user can set to disable the Web Browser content in reports.
On the main clinical window, under the Review Options outline, there is the "Show report documentation on report selector" option:
Unchecking that option will prevent the Web Browser from showing and allow users to run reports and open files without the warnings. Note that the other option, "Show report descriptions on report selector," is OK and may be desired, as it describes the selected report.
Details
Operating System
Windows
Reported Version
19.1.4
Products JMP Clinical
