JMP Knowledge Base
JMP® Clinical Adverse Event Report is incorrectly labeling columns with wrong treatment group
For some studies in JMP Clinical columns of the Adverse Event Report containing counts and percents are labeled with the wrong treatment group. To resolve this issue the two files attached to this note need to replace the existing files. To update these files please close JMP Clinical. Then use these files:
adverseeventsreport.sas should be copied to C:\Program Files\SASHome\JMPClinical\14\Clinical\ProcessLibrary\.
utilitymacros.sas should be copied to C:\Program Files\SASHome\JMPClinical\14\LifeSciences\MacroLib\.
[Previously JMP Note 65257]
Details
Operating System
Windows
Reported Version
7.0
Products JMP Clinical
