JMP Knowledge Base
JMP® Clinical 8.0 translation errors occur for the Chinese language
JMP Clinical 8.0 contains two translation errors for the Chinese language.
In the Show Patients at Risk drill-down information, the output contains an untranslated string.
In the DefaultBySubjectChinese or DefaultByEventChinese template that is used for the Adverse Event Narrative, the output contains an incorrect translation for information about sex.
Click here to access the Hot Fix for this issue.
[Previously JMP Note 67842]
Details
Operating System
Windows
Reported Version
8.0
Products JMP Clinical
