JMP Knowledge Base
JMP® Clinical 7.1 Adverse Event Narrative templates do not split prior and con meds based on study day
In JMP Clinical 7.1 there is not a standard way of splitting medications into prior treatment vs. on treatment. This hot fix standardizes this based on study day.
The split is now based on study day and is calculated in loaddata to split prior and conmeds. The standardization uses the study day when available, and then either the first of the month if day is missing or the first of the year if month and day are missing.
The changes are implemented by the Hot Fix available here.
[Previously JMP Note 65478]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
