JMP Knowledge Base
JMP® Clinical 7.1 API JSL results in an error when try to remove section
In JMP® Clinical 7.1 when trying to remove section using the JSL API, the following error can occur:
The symbol "TabFilterReferenceList" is not defined in namespace "results" in
access or evaluation of 'results:TabFilterReferenceList' ,
results:TabFilterReferenceList/*###*/
This issue is resolved by the Hot Fix available here.
[Previously JMP Note 64957]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
