JMP Knowledge Base
JMP® Clinical 7.1.2 Risk Based Monitoring might result in errors when you add supplemental data
This note addresses several issues with JMP Clinical 7.1.2 Risk Based Monitoring when supplemental data is used.
  1. While adding supplemental data, JMP Clinical 7.1.2 Risk Based Monitoring might generate an error similar to the following:
       Unexpected ";".
       Trying to parse operand for "=" operator.
       Line XX Column YY: objRefNS:NoActFlg = ?;
  2. When you add supplemental data, JMP Clinical 7.1.2 Risk Based Monitoring coloring might be incorrect, with either no rows colored, or only the first row colored.
  3. When you add supplemental data summarized by site, JMP Clinical 7.1.2 Risk Based Monitoring might not run.
To circumvent these errors, save the file found here. The file should be named RiskBasedMonitoring.sas and should be saved in this location: C:\Program Files\SASHOME\JMPClinical\14\Clinical\ProcessLibrary. The new file that you download here should replace the existing RiskBasedMonitoring.sas file that is found in this folder.
[Previously JMP Note 66348]
Details
Operating System
Windows
Reported Version
7.1
Products JMP Clinical
