JMP Knowledge Base
JMP® Clinical 6.1 hotfix for Add Study issues
The Hot Fix available here for JMP® Clinical 6.1 resolves four issues for Add Study.
1.  This Hot Fix allows JMP Clinical 6.1 to be compatible with SAS® 9.4 TS1M5, and allows studies to be added to JMP Clinical when SAS 9.4 TS1M5 is installed.
This Hot Fix also resolves the following errors:
2.  The following error may also occur in JMP Clinical 6.1 when adding a study:
ERROR: The following domains are duplicated in at least two datasets: RE
ERROR: Creation of MetaData Failed.
3.  The following error may also occur in JMP Clinical 6.1 when adding a study with adqmadrs in the ADaM folder.
ERROR: Library SDTM does not exist.
4.  JMP Clinical 6.1 may result in an error when adding a study where ADSL contains only trt01a, but no trt01p, arm, nor trt01n.
[Previously JMP Note 61832]
Details
Operating System
Windows
Reported Version
6.1
Fixed Version
7.0
Products JMP Clinical
