JMP Clinical 6.1 errors when Animal Profiles are run with PDF and RTF unchecked
Created:
Nov 30, 2022 04:36 PM
| Last Modified: Jan 6, 2023 5:37 AM
In JMP Clinical 6.1 if the Animal Profile report is run with both PDF and RTF unchecked, the report tries to run but an error will occur. The Hot Fix available here resolves this error.
[Previously JMP Note 61822]
Details
Operating System
Windows
Reported Version
6.1
ProductsJMP Clinical
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '575415' && "TkbArticlePage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '575415') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if ("TkbArticlePage" == "IdeaPage") {
if (value == '575415') {
if ("TkbArticlePage" == "TkbArticlePage") {
if(subTkbElement){
else if ("TkbArticlePage" == "BlogArticlePage") {
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
