JMP Knowledge Base
JMP® Clinical 6.1 does not use supplemental domains by default
JMP® Clinical 6.1 does not use supplemental domains, by default. To resolve the problem, apply the Hot Fix available here. For domain distribution reports at subject level the option to Merge Supplemental data is now on by default. This affects Distribution reports for the following domains:  AE, Events, Interventions, Findings and Study Visits.
[Previously JMP Note 60239]
Details
Operating System
Windows
Reported Version
6.1
Products JMP Clinical
