JMP Knowledge Base
JMP® Clinical 6.1 Adverse Event Narratives do not handle Supplemental Data
This Hot Fix allows supplemental data to be used in Adverse Events Narratives in JMP® Clinical 6.1.
One option is to specify the full path and name to the input SAS data set containing supplemental data for AE narratives. This data set merges events using USUBJID and AESEQ. If AESEQ is not available in the original SDTM or ADAM data, AESEQ is defined after sorting events by USUBJID, AESTDTC, and AETERM for events where AETERM is non-missing. This allows the merger on any data for each AE.
Additionally this Hot Fix handles AEOUT and AEACN in a multiple treatment study. In particular, these important grouping AE variables can be defined for each treatment making it much easier to evaluate in the AE Distribution report.
To use these enhancements apply the Hot Fix available here.
[Previously JMP Note 60237]
Details
Operating System
Windows
Reported Version
6.1
Products JMP Clinical
