JMP Knowledge Base
JMP® Clinical 6.0 results in an error that LBTESTCD values are not unique when analyzing findings data
The following error can occur in JMP® Clinical 6.0 when analyzing findings:
ERROR: Analysis cannot be completed because the LBTESTCD values are not unique across values of test category and/or subcategory.
To work around this problem, replace the old FindingsMacros.sas file that is located in C:\Program Files\SASHome\JMPClinical\12\LifeSciences\MacroLib with this new FindingsMacros.sas file.
[Previously JMP Note 58772]
Details
Operating System
Windows
Reported Version
6.0
Products JMP Clinical
