JMP Knowledge Base
JMP® Clinical 5.0 Cluster Subjects Across Study Sites might give empty results window
There is an issue in JMP® Clinical 5.0 where the results from Cluster Subjects Across Study Sites are blank. This occurs when run after Cluster Subjects Within Study Sites. This Hot Fix addresses the issue for viewing output from reports when analyzed within the same Clinical Review:
  • Cluster Subjects Across Study Sites
  • Cluster Subjects Within Study Sites
This has been fixed so that both reports can be included within the same Clinical Review. The Hot Fix for this issue is available here.
[Previously JMP Note 52957]
Details
Operating System
Windows
Products JMP Clinical
