JMP Knowledge Base
JMP 18 Import Multiple File, imports duplicate columns appends with 1, 2, etc. with no defined order.
Issue
Importing a file with multiple columns with the same name will have no clear defined order. In earlier JMP versions, the columns would import as Column 1, Column 2, Column 3, etc. Now, they import as column 3, column 2, and column 1 without any clear ordering.
Workaround
Import the files using JSL or File > Open and concatenate the tables.
Details
Operating System
Windows
Reported Version
18.0
Products JMP JMP Pro JMP Clinical
