JMP Knowledge Base
JMP® 15 does not recognize tables when opening .mdb or .accdb files.
Tables produced by opening a .accdb or .mdb file are not recognized when using the drag and drop method or using File > Open. As a result, any subsequent actions, such as choosing Analyze > Fit Y by X or selecting the table from the Current Data Table drop-down will not see the opened table.
Workaround:
  1. Run the source script within the table, which produces a new table that is recognized.
  2. Import the .accdb or .mdb files via File > Database > Open Table or Query Builder (ODBC).
[Previously JMP Note 65471]
Details
Operating System
Windows
Reported Version
15.0
Fixed Version
16.0
Products JMP JMP Pro
