JMP Knowledge Base
JMP® 15 and newer will not install on 32-bit operating systems
If you install JMP 15 or a newer version, you might encounter an error message that is similar to the following:
The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) versions of the program, and then contact the software publisher.
This message appears when you are likely running JMP on a 32-bit operating system. JMP 15 and newer installers are 64-bit only, per JMP System Requirements. There are no 32-bit installers.
If you are unable to obtain a supported operating system for JMP 15 and newer versions, contact JMP Sales to discuss your options.
[Previously JMP Note 66060]
Details
Operating System
macOS Windows
Reported Version
15.0
Products JMP JMP Pro
