JMP Knowledge Base
JMP® 13 Documentation Library book is displayed in JMP version 14.0
If you are running JMP® Version 14.0 in Japanese or Simplified Chinese on a Macintosh machine and you open the "JMP Documentation Library" book, JMP displays an older version of the documentation. Selecting Help ► Books ► JMP Documentation Library opens the JMP 13 translated version of the documentation. The proper JMP 14 version of this book can be found in the Library folder on the machine:  /Library/Documentation/Applications/JMP/14.
[Previously JMP Note 61838]
Details
Operating System
macOS
Reported Version
14.0
Fixed Version
14.1
Products JMP JMP Pro
