JMP Knowledge Base
Is the Mann-Whitney U Test Available in JMP®?
Yes. It is equivalent to the Wilcoxon 2-sample (or Kruskal Wallis k-sample) Test. This is obtained from the Fit Y by X platform by fitting a continuous Y and a nominal or ordinal X and then selecting Nonparametric ► Wilcoxon Test from the Oneway Analysis pull-down menu.
[Previously JMP Note 35809]
Details
Operating System
macOS Windows
Products JMP
