JMP Knowledge Base
Incidence Screen label names are truncated on graphs and in data tables
In JMP® Clinical 7.1 in Incidence Screen output, when there are long values within a column that are used as label names on graphs or in data tables, the label names are truncated on graphs and in data tables.
This issue is corrected in the JMP® Clinical 7.1.2 Hot Fix.
Click here to access the hot fix for this issue.
[Previously JMP Note 65970]
Details
Operating System
Windows
Reported Version
7.1
Products JMP Clinical
