JMP Knowledge Base
In Multivariate Inliers and Outliers, using Variable Contributions plot and Explore Outliers options can produce an error in JMP® Clinical
Using the Explore Outliers tool within the Variable Contributions to Distance plot might produce the following JMP® Alert message:
The symbol "outs" is not defined in namespace "objRefNS" in access or evaluation of 'objRefNS:outs' , objRefNS:outs/*###*/
This error occurs when a user creates the Multivariate Inliers and Outliers (MVIO) report, runs another report, then goes back to use the Variable Contributions to Distance and Explore Outliers options within MVIO.
The issue is resolved in the JMP® Clinical 7.0.1 hotfix.
[Previously JMP Note 63715]
Details
Operating System
Windows
Reported Version
7.0
Fixed Version
7.1
Products JMP Clinical
