JMP Knowledge Base
In JMP® Clinical 7.1, Add Study fails when a study is blinded and has SUPPDM but no ADSL data set
When a study is blinded and has SUPPDM but no ADSL data set, refreshing the study metadata produces an error.
As a workaround, create an ADSL data set with only a USUBJID column that is populated and copied from SDTM. Adding the study with this ADSL data set is successful.
The issue is corrected in the JMP® Clinical 7.1.1 hotfix.
[Previously JMP Note 65441]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
