JMP Knowledge Base
In JMP® Clinical 7.1 AE Narratives, results are incorrect if Event Type selection is not set to Treatment Emergent Events
In JMP® Clinical 7.1, the AE Narrative results are incorrect if the Event Type selection is not set to "Treatment Emergent Events." When a user chooses the template "ByNarrativeCategoryDetails" or "ByNarrativeCategorySummary," the Event Type selection must be "Treatment Emergent Events" for the results to be correct.
This issue is corrected in the JMP® Clinical 7.1.1 hotfix.
[Previously JMP Note 65332]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
