JMP Knowledge Base
In JMP Clinical® 6.0, username length might cause metadata table name to exceed 32 character limit
In JMP Clinical® 6.0, username length might cause the metadata table name to exceed the 32 character limit for SAS® data table names.
Additionally, when JMP Clinical 6.0 is launched with a username containing the special character " – " only base JMP opens and the JMP Clinical menus do not appear.
To resolve the errors, the user needs to extract the files from the zip file referenced below to the JMP Clinical install directory that, by default (if no changes were made and the SASHome directory is within the Program Files directory), is named:
C:\Program Files\SASHome\JMPClinical\12
The user also needs to run Generate Dialogs under Advanced in the Settings window. Click on the attachment on the right to download the zip file.
Note that following the steps above also fix the SAS transport file issue described in JMP Note 575176. If a user also encounters that issue, there is no need to go through both processes, as the fix provided in this note addresses that issue as well.
[Previously JMP Note 59075]
Details
Operating System
Windows
Reported Version
6.0
Products JMP Clinical
