JMP Knowledge Base
I have categorical effects in my Stepwise Regression model, and I don't understand how JMP® is performing the analysis. Is there any information on this?
Information on Stepwise Regression models containing nominal and/or ordinal effects can be found in the JMP® Fitting Linear Models documentation. In the Stepwise Regression Models chapter, see the section titled Models with Nominal and Ordinal Effects.
[Previously JMP Note 36624]
Details
Operating System
macOS Windows
Products JMP
