JMP Knowledge Base
How to transition JMP® to a centralized license method pre-installation (for Microsoft Windows only)
If you are deploying JMP on Windows for the first time and you want to centralize the location of your JMP license, here are the steps to follow:
  1. Create a jmp.per file by installing JMP on a test machine and licensing JMP by using the Open License prompt. The jmp.per file is stored in the JMP installation directory: C:\Program Files\SAS\JMP<PRO>\<version>\JMP.PER
  2. Save the jmp.per file on a network share.
  3. Open Notepad and create a file that is named jmp.pfs.
  4. In the jmp.pfs file, add the following lines:
       Preferences(
    File Location Settings(
    License File Path( "\\network-share-path\...\jmp.per" )
  5. In place of the network-share-path above, enter the path to the jmp.per file (the save destination in Step 2) as the argument.
  6. See the Adding Custom Files to a Software Depot section in the JMP Deployment Guide, and place the jmp.pfs file in the custom/pfs folder as explained in the guide.
  7. For new installations of JMP, upon installation, JMP writes the jmp.pfs file to C:/ProgramData/SAS/JMP<Pro>/.
  8. When JMP launches, it copies the jmp.pfs file from the ProgramData directory to the user directory, pointing JMP to the jmp.per file path that is specified in Step 5.
Note: When your site renews JMP for a specific version, you must repeat Step 1 above to generate a new jmp.per file. This new jmp.per file then replaces the older jmp.per file that you saved in Step 2.
For more information, see the JMP Deployment Guides.
[Previously JMP Note 66461]
Details
Operating System
Windows
Products JMP JMP Pro
