JMP Knowledge Base
How to select rows based upon multiple conditions using a JMP® script
Overview
The following examples demonstrate how you can use the logical AND (&) and OR (|) operators with the Select Where message to select rows that meet multiple conditions.
Instructions
In a JMP® session, click the File menu and select New ► Script. Copy the below script and paste it into the script window. To run the sample script, click the Edit menu and select Run Script.
/* Open a sample data table */
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
/* Select rows where students are over 13, who are also less than 65 inches tall */
dt << Select Where( :age > 13 & :height < 65 );
Wait( 2 ); // For demonstration purposes
dt << Clear Select; // For demonstration purposes
/* Select rows where students are either 12 or 14 years old */
dt << Select Where( :age == 12 | :age == 14 );
Additional Documentation
More information about the JMP Scripting Language can be found in the Scripting Guide available in the online help.
[Previously JMP Note 49517]
Details
Operating System
macOS Windows
Products JMP JMP Pro
