The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
Get the free JMP Student Edition for qualified students and instructors at degree granting institutions.
View Original Published Thread
Syndicated - OutboundJMP Note 575399 - How to script Column Properties using variables
Overview
When using the JMP® Scripting Language (JSL) to script a column property, it is important to understand that the column is simply a repository for all column properties. The column stores the column property with the values supplied without evaluation or validation of the supplied arguments. In order to add column properties using JSL code which contains variables, the script must convert any variables to their actual values.
One way to do this is to use expressions. In the following example, the Eval Expr() function evaluates and replaces any variable wrapped in the Expr() function with its value. The outer Eval() function evaluates the entire statement after the replacement has occurred.
Instructions
In a JMP session, click the File menu and select New ► Script. Copy the below script and paste it into the script window. To run the sample script, click the Edit menu and select Run Script.
/* Open a sample data table */
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
/* Assign desired spec limits */
lLimit = 55;
uLimit = 70;
tLimit = 62.5;
/* Store the limits in the Spec Limits column property */
Eval(  //Evaluates the entire expression after the replacement has occurred
	Eval Expr(  //Evaluates and replaces any variable wrapped in the Expr() function with its value
		:height << Set Property(
			"Spec Limits",
			{LSL( Expr( lLimit ) ), USL( Expr( uLimit ) ), Target( Expr( tLimit ) ), Show Limits( 0 )}
Additional Documentation
More information about the JMP Scripting Language can be found in the JMP Scripting Guide. You can access the guide from within JMP by clicking on the Help menu and select JMP Help.  From the online Table of Contents, choose Scripting Guide.
[Previously JMP Note 46953]
Comments
How would I prompt the user for the lLimit, uLimit and tLimit?
Details
Operating System
macOS Windows
Products JMP JMP Pro
