JMP Knowledge Base
How to build a Databricks Data Connector in JMP®.
Connecting to Databricks can be challenging because many standard ODBC configurations do not work as expected. This is partly due to differences between how JMP® interacts with system tables in traditional relational databases and how Databricks is architected.
To establish a Databricks connection from JMP, a Data Connector is required. The Data Connector allows users to add unique parameters that are often not provided or easy to find in some open-source ODBC drivers.
Below is a list of instructions to help you get started.
Build a Data Connector for Databricks by letting JMP pull parameters from an existing DSN:
  1. From JMP, click File > Connect To > Data Connector.
  2. Click New Connection.
  3. JMP will pull a list of DSNs from the ODBC Data Sources (64-bit) tool and a default set of data connectors shipped with JMP.
  4. JMP will pull in the DSN you created for Databricks.
  5. To modify it, click it and select New.
  6. JMP will open the Data Connector Editor based on the Simba DSN you selected.
Add Catalog:
To add, type Catalog=<catalog_name> in the Connection dialog.
Disable Block Fetch:
In the Data Connector, expand the ODBC section. Select the drop-down next to Block Fetch and select OFF.
Add Backticks:
Expand the SQL section within the Data Connector. Next to Quote Type, click the drop-down. Select Backticks.
Test and Save your Data Connector.
Click Test to ensure the connection succeeds. Save your Data Connector (DC) with a unique name to help you easily identify it for future use. E.G. DC_Databricks_<CATALOG>.
Details
Operating System
macOS Windows
Products JMP JMP Pro
