JMP Knowledge Base
How do I report a problem I am having with JMP?
There are four ways that you can access JMP Technical Support:
  • Telephone Support: You can receive telephone support by calling (800) 450-0135 between 9:00 AM and 5:00 PM Eastern Time.
  • E-mail Support: You can communicate with SAS Technical Support by sending e-mail to [email protected]. You can send messages 24 hours a day, seven days a week. You can use this method to report new problems and supply additional information to previously tracked problems.
  • Internet Support: JMP Technical Support's Web site offers a range of tools, tips, and information that is designed to help you solve your problem. You can search our Knowledge Base & FAQS and use our FTP site to obtain technical information, fixes, and samples. You can also contact Technical Support by filling out an online Problem Report.
  • Fax Support: You can fax your problem to (919)-677-4444. You can fax a problem 24 hours aday, 7 days a week.
If you are an international customer and are in need of technical support, please contact your local SAS international office.
When contacting Technical Support, please have the following information available:
  • Your JMP® site or serial number.
  • The JMP® version that you are using.
  • Your operating environment, such as Windows 7 or Macintosh 10.10.
[Previously JMP Note 35299]
Details
Operating System
macOS Windows
Reported Version
15.0
Fixed Version
16.1
Products JMP JMP Pro JMP Live JMP Clinical
