How do I interpret the saved spline coefficients table in JMP®?
Created:
Nov 30, 2022 04:34 PM
| Last Modified: Feb 5, 2023 2:01 AM
The coefficients are the A (intercept), B (linear), C (quadratic), and D (cubic) coefficients for the variable (x-O), where O is the variable for the knot at the beginning of the interval.
[Previously JMP Note 35350]
Details
Operating System
macOS
Windows
ProductsJMP
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '575362' && "TkbArticlePage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '575362') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if ("TkbArticlePage" == "IdeaPage") {
if (value == '575362') {
if ("TkbArticlePage" == "TkbArticlePage") {
if(subTkbElement){
else if ("TkbArticlePage" == "BlogArticlePage") {
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
