JMP Knowledge Base
How do I get an analysis using CODED or UNCODED effects in JMP®?
There are at least two methods to get coded effects. In the results window from a Fit Model analysis, click on the inverted red triangle menu and select Effect Screening ► Scaled Estimates. Alternatively, the "Coding" column property can be set for the effects. Column Properties are defined in the Column Info dialog.
[Previously JMP Note 35439]
Details
Operating System
macOS Windows
Products JMP JMP Pro
