JMP Knowledge Base
How do I generate Multivariate Normal data within JMP®?
The script entitled MVN.jsl attached can generate multivariate normal data.
Simply supply the variance covariance matrix, a vector of means, and the desired sample size, and the script generates the data.
Also, if you are fitting a model with the Fit Model platform and want to generate factor values coming from a defined multivariate normal distribution, the Simulator in the Prediction Profiler can be used. For this approach, select "Multivariate" for each factor and define the mean, standard deviation, and correlation structure (under the X Correlation Specification outline) then click the "Simulate" button (or Click the "Make Table" button to simulate the results of N Runs to a data table).
[Previously JMP Note 36140]
Details
Operating System
macOS Windows
Products JMP
