JMP Knowledge Base
How do I change the level of the event modeled in JMP®’s logistic regression?
By default, JMP® models the lower ordered level as the event. The Target Level column property can be used to reverse the order of the levels. Highlight the response column, click Cols ► Column Info, then click Column Properties to add a Target Level column property.
Also, where applicable in JMP, the Target Level can be specified in the Model Dialog as a drop-down menu item.
[Previously JMP Note 35409]
Details
Operating System
macOS Windows
Products JMP
