JMP Knowledge Base
How can I reproduce the results I obtain in JMP® with centered polynomial terms using the GLM procedure in SAS®?
The following SAS® code demonstrates how to reproduce the JMP® results using PROC GLM.
SAS INSTITUTE INC. IS PROVIDING YOU WITH THE COMPUTER SOFTWARE CODE INCLUDED WITH THIS
AGREEMENT ("CODE")ON AN "AS IS" BASIS, AND AUTHORIZES YOU TO USE THE CODE SUBJECT TO THE
TERMS HEREOF. BY USING THE CODE, YOU AGREE TO THESE TERMS. YOUR USE OF THE CODE IS AT
YOUR OWN RISK. SAS INSTITUTE INC. MAKES NO REPRESENTATION OR WARRANTY, EXPRESS OR
IMPLIED, INCLUDING, BUT NOT LIMITED TO, WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
PARTICULAR PURPOSE, NONINFRINGEMENT AND TITLE, WITH RESPECT TO THE CODE.
data test;
    input pressure totalflow gasratio thickness ;
    cpres=pressure-180;
    ctflow=totalflow-450;
    cgasrat=gasratio-4.5;
cards;
180	450	4.5	900.87	15.53
160	500	6	1060.157	16.14
200	400	3	1052.14	15.99
160	400	6	1220.278	12.98
180	450	4.5	940.87	15.62
160	500	3	565.6048	16.35
200	500	3	1278.004	15.83
180	450	4.5	912.87	15.73
200	500	6	757.558	16.71
200	400	6	569.0499	15.64
180	450	4.5	935.87	15.55
/* GLM reproduces results from JMP Center Polynomial */
proc glm data=test;
    model thickness=pressure totalflow gasratio cpres*ctflow
                               cpres*cgasrat ctflow*cgasrat;
run;
/* GLM reproduces results from JMP without the Center Polynomial */
proc glm data=test;
    model thickness=pressure totalflow gasratio pressure*totalflow
                                pressure*gasratio totalflow*gasratio;
run;
[Previously JMP Note 37926]
Details
Operating System
macOS Windows
Products JMP JMP Pro
