JMP Knowledge Base
How can I get my JMP results into another application?
There are two methods for transferring your analysis results from JMP® to another application:
    • Copy the results in JMP then paste them into the other application.
      1. Select the analysis results using the Selection tool.
      2. Select Copy from the Edit menu.
      3. Paste the results in the other application.(Some applications may use "Paste Special")
  • Create a JMP journal then save the journal as an RTF, HTML, JPEG, PNG, or WMF (Windows only).
    1. Select Journal from the Edit menu with the analysis windows as the active window.
    2. Select Save from the File menu.
    3. Select a format in which to save the journal.
    4. Open the saved file in the other application.
[Previously JMP Note 35313]
Details
Operating System
macOS Windows
Products JMP JMP Pro
