JMP Knowledge Base
How are the confidence limits calculated for the linearity study in JMP®?
where:
= the critical value of T
= the number of levels for the Standard variable
= the sum of the number of levels for the standard divided by the number of levels for the factor
= the degrees fo freedom for the term(s) in the model
[Previously JMP Note 36125]
Details
Operating System
macOS Windows
Products JMP
